Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Remove the heating coil by unraveling it from the heating element. To replace, you'll need to re-wrap a new wire around the coil and attach it to the wires at the bottom (see Step 8).
