Introduction
If you're confident in your repair skills, use this guide to replace the heating coil in the heart of your heat gun.
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Tool used on this step:Tweezers$3.99
Use the angled tweezers to remove the heating coil end from the input point.
