Drill Master Heat Gun Heating Coil Replacement
  1. Drill Master Heat Gun Heating Coil Replacement, Heating Coil: step 1, image 1 of 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Heating Coil Replacement: step 2, image 1 of 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Heating Coil Replacement: step 3, image 1 of 3 Drill Master Heat Gun Heating Coil Replacement: step 3, image 2 of 3 Drill Master Heat Gun Heating Coil Replacement: step 3, image 3 of 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Heating Coil Replacement: step 4, image 1 of 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Heating Coil Replacement: step 5, image 1 of 1
    • Remove the plastic casing from the end of the barrel.
  6. Drill Master Heat Gun Heating Coil Replacement: step 6, image 1 of 1
    • Remove the metal casing from the heating element.
  7. Drill Master Heat Gun Heating Coil Replacement: step 7, image 1 of 1
    • Slowly remove the heat resistant wrapping from the heating element.
    • Be careful here - the wrapping can be easily torn!
  8. Drill Master Heat Gun Heating Coil Replacement: step 8, image 1 of 2 Drill Master Heat Gun Heating Coil Replacement: step 8, image 2 of 2
    • Use the angled tweezers to remove the heating coil end from the input point.
  9. Drill Master Heat Gun Heating Coil Replacement: step 9, image 1 of 1
    • Remove the heating coil by unraveling it from the heating element.
    • To replace, you'll need to re-wrap a new wire around the coil and attach it to the wires at the bottom (see Step 8).
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 61
All Time: 4,126
