Introduction
If you're confident in your repair skills, use this guide to replace the heating coil in the heart of your heat gun.
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the heating coil by unraveling it from the heating element.
Hi,
it looks like there is a thermal fuse between the end of the blue cord and the heating element. Would it be possible to get the specifications or any other data which is written on it?
Thank you.
best wishes,
berthold
AUP0 AF133
Tf133°C G1
Silver casing, red lettering, black forward-most plastic “nose” bit
Will the gun still blow air if the heating coil is removed? I just need the air blowing function of a mini heat gun; focused air stream for crafts.
2 other people completed this guide.
3 Comments
Where are the heating coil wires found?
I am asking where I can find a NEW heating coil wire?
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
