Introduction
This guide will show how to replace damaged casing on the Dremel MultiPro 395.
Tool used on this step:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
Remove the black housing cap from the Multipro located directly below the chuck cap.
There are 2 more Torx screws under the housing cap on my model 395. I haven't figured out what size screws they are yet, but they're smaller than the other 4 Torx screws in the case.
2 other people completed this guide.
