Introduction
This is a prerequisite guide only. In the following steps, you will remove two exterior parts, then remove the screws that hold the casing together.
Start by removing the housing cap by unscrewing it.
Next, unscrew the now exposed collet nut while holding down the shaft lock button.
Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
