This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Remove the carbon brushes with a thin screwdriver. 3 mm - Exercise caution as they are fragile.
To avoid damaging the label, peel it off halfway, starting from the indicated spot.
Remove the power cord screws.
Pull up the assembly with the shaft and unclip the plastic part from the speed controller.
Be careful with the inductor wires, as they are thin and may break; there are 4 pins that make contact with the coil.
Reassemble carefully.
For reassembly of your device, follow these instructions in reverse order.
3 other people completed this guide.
