Dreamer Autoshade Driver Blocking
  1. Dreamer Autoshade Driver Blocking, Remove motor hub fasteners: step 1, image 1 of 2 Dreamer Autoshade Driver Blocking, Remove motor hub fasteners: step 1, image 2 of 2
    • Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
  2. Dreamer Autoshade Driver Blocking, Remove driver bearing cap: step 2, image 1 of 2 Dreamer Autoshade Driver Blocking, Remove driver bearing cap: step 2, image 2 of 2
    • Using a flathead screwdriver, pry the bearing cap from the tube.
  3. Dreamer Autoshade Driver Blocking, Loosen PCB mounting Screws: step 3, image 1 of 3 Dreamer Autoshade Driver Blocking, Loosen PCB mounting Screws: step 3, image 2 of 3 Dreamer Autoshade Driver Blocking, Loosen PCB mounting Screws: step 3, image 3 of 3
    • Use a #1 Phillips head screwdriver to loosen the PCB mounting screws until the circuit board can be adjusted. This should only take 1-2 full rotations of the screwdriver. Do not fully remove the screws.
  4. Dreamer Autoshade Driver Blocking, Straighten PCB: step 4, image 1 of 1
    • The circuit board can cause problems if it is not properly centered on the sheet metal mount. See the picture for details.
    • The blue lines in the picture show the edges of the white metal PCB plate, while the red lines show the edge of the PCB. Adjust the PCB so it lines up as closely as possible with the metal plate. This will ensure that the PCB does not contact the edge of the tube while rotating.
  5. Dreamer Autoshade Driver Blocking, Tighten PCB mounting screws: step 5, image 1 of 1
    • Tighten the two PCB mounting screws until the PCB cannot move freely.
David
734 Reputation
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 119
