Dreame T30: Display Replacement
    1. Dreame T30: Display Replacement, Remove the battery: step 1, image 1 of 3 Dreame T30: Display Replacement, Remove the battery: step 1, image 2 of 3 Dreame T30: Display Replacement, Remove the battery: step 1, image 3 of 3
      • Begin by removing the removable battery.
      Ask FixBot
    2. Dreame T30: Display Replacement, Remove the bottom lid.: step 2, image 1 of 3 Dreame T30: Display Replacement, Remove the bottom lid.: step 2, image 2 of 3 Dreame T30: Display Replacement, Remove the bottom lid.: step 2, image 3 of 3
      • Use a T10 torx screwdriver to remove the screw.
      • Then use a prying tool of some sort (Jimmy) to loosen the latches.
      • Finally, remove it.
      Ask FixBot
    3. Dreame T30: Display Replacement, Remove the dustbin.: step 3, image 1 of 2 Dreame T30: Display Replacement, Remove the dustbin.: step 3, image 2 of 2
      • Push the tab.
      • Pull it off.
      Ask FixBot
    4. Dreame T30: Display Replacement, Remove the inner lid: step 4, image 1 of 3 Dreame T30: Display Replacement, Remove the inner lid: step 4, image 2 of 3 Dreame T30: Display Replacement, Remove the inner lid: step 4, image 3 of 3
      • It is only latched on.
      • Use a prying tool to force a gap.
      Ask FixBot
    5. Dreame T30: Display Replacement, Remove the cables from the PCBA: step 5, image 1 of 3 Dreame T30: Display Replacement, Remove the cables from the PCBA: step 5, image 2 of 3 Dreame T30: Display Replacement, Remove the cables from the PCBA: step 5, image 3 of 3
      • Remove the positive and negative leads of the suction fan from the pcba.
      • Negative is a T8 Torx, positive is PH2.
      Ask FixBot
    6. Dreame T30: Display Replacement, Remove the cables from the PCBA: step 6, image 1 of 2 Dreame T30: Display Replacement, Remove the cables from the PCBA: step 6, image 2 of 2
      • Disconnect the rest of the cables and remove the middle screw.
      • It is a T10 Torx.
      • Once the screw is removed, push the PCBA out. Simply push on the battery connector.
      Ask FixBot
    7. Dreame T30: Display Replacement, Removing the handle: step 7, image 1 of 3 Dreame T30: Display Replacement, Removing the handle: step 7, image 2 of 3 Dreame T30: Display Replacement, Removing the handle: step 7, image 3 of 3
      • Back up top, pull the 2 top wires through the gap.
      • You will now have to push the little grey button and the red trigger button in while applying some upwards pressure to loosen the handle.
      Ask FixBot
    8. Dreame T30: Display Replacement, Removing the handle: step 8, image 1 of 2 Dreame T30: Display Replacement, Removing the handle: step 8, image 2 of 2
      • Now, simply pull the handle out.
      • Rotate back to the front and remove the 2 marked screws. They're T10 Torx.
      Ask FixBot
    9. Dreame T30: Display Replacement, Removing the handle chassis: step 9, image 1 of 3 Dreame T30: Display Replacement, Removing the handle chassis: step 9, image 2 of 3 Dreame T30: Display Replacement, Removing the handle chassis: step 9, image 3 of 3
      • To remove the handle chassis, insert a prying tool into the marked gap.
      • Do not fit it into the bigger round hole to the left. Fit it into the hole on the right side, which is significantly tighter.
      • I use my looong Phillips screwdriver for this.
      • Then, simply apply adequate force in the direction of the arrow.
      Ask FixBot
    10. Dreame T30: Display Replacement, Cables: step 10, image 1 of 2 Dreame T30: Display Replacement, Cables: step 10, image 2 of 2
      • Now, pull the chassis off, but only enough to expose the pcba and not any more.
      • Remove the small screw from the PCBA. It is a Torx T6.
      • Disconnect the cable from the PCBA, then pull the other cables through the gap in the PCBA.
      Ask FixBot
    11. Dreame T30: Display Replacement, Remove the display's cable from the housing: step 11, image 1 of 2 Dreame T30: Display Replacement, Remove the display's cable from the housing: step 11, image 2 of 2
      • Lead the cable out of the housing as you remove the chassis.
      Ask FixBot
    12. Dreame T30: Display Replacement, Remove the display from the chassis: step 12, image 1 of 3 Dreame T30: Display Replacement, Remove the display from the chassis: step 12, image 2 of 3 Dreame T30: Display Replacement, Remove the display from the chassis: step 12, image 3 of 3
      • Remove the marked screws.
      • They are Torx T10.
      • After removing the screws, push the display out. I usually just use the screwdriver to do so, as it is not held in by anything.
      Ask FixBot
    13. Dreame T30: Display Replacement: step 13, image 1 of 3 Dreame T30: Display Replacement: step 13, image 2 of 3 Dreame T30: Display Replacement: step 13, image 3 of 3
      • After removing the display, simply disconnect the cable. You can now replace it or disassemble it further to replace only the display or the PCBA with buttons.
      • To do so, remove the 2 screws holding the assembly together. They are T10 Torx.
      • Once you've replaced what is needed, simply reassemble it, then attach the cable and put it back into the chassis.
      Ask FixBot
    14. Dreame T30: Display Replacement, Screeeeews: step 14, image 1 of 1
      • All are sorted by steps and have type written above them.
      • Use this as a reference during reassembly if necessary.
      Ask FixBot
    15. Dreame T30: Display Replacement, Box.: step 15, image 1 of 1
      • Why do they love boxes so much more than the toys?
      Ask FixBot
DegenFixer
5,750 Reputation
24 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 157
All Time: 1,414
