Dreamcast CMOS Battery Replacement
  1. Dreamcast CMOS Battery Replacement, Top Cover: step 1, image 1 of 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  2. Dreamcast CMOS Battery Replacement: step 2, image 1 of 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  3. Dreamcast CMOS Battery Replacement, Controller Port: step 3, image 1 of 2 Dreamcast CMOS Battery Replacement, Controller Port: step 3, image 2 of 2
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
  4. Dreamcast CMOS Battery Replacement: step 4, image 1 of 2 Dreamcast CMOS Battery Replacement: step 4, image 2 of 2
    • Remove the four 14mm Philips #02 screws located on the controller board.
  5. Dreamcast CMOS Battery Replacement: step 5, image 1 of 2 Dreamcast CMOS Battery Replacement: step 5, image 2 of 2
    • Disconnect the white fan header from the controller port.
  6. Dreamcast CMOS Battery Replacement: step 6, image 1 of 2 Dreamcast CMOS Battery Replacement: step 6, image 2 of 2
    • Remove the controller board by lifting it up from the controller port.
  7. Dreamcast CMOS Battery Replacement, CMOS Battery: step 7, image 1 of 1
    • Note where the positive and negative terminals go.
    • Desolder the old CMOS battery from the controller board.
  8. Dreamcast CMOS Battery Replacement: step 8, image 1 of 1
    • Solder the replacement battery holder to two electrical wires.
    • Solder the opposite ends of the wires to the controller board. Make sure to match corresponding points on the board with where the previous positive and negative terminals were.
  9. Dreamcast CMOS Battery Replacement: step 9, image 1 of 1
    • Reinsert the controller board.
    • Attach the battery holder inside with a self adhesive substance, such as double sided foam tape.
    • Insert the battery into the battery holder.
    • Reverse the disassembly directions to reassemble your Dreamcast.
    • Once your Dreamcast is reassembled, go ahead and connect the Dreamcast to your TV or monitor and power, and reset the clock.
Dark Sakul
819 Reputation
1 Guide authored
Past 24 Hours: 11
Past 7 Days: 121
Past 30 Days: 646
All Time: 80,815
