Doss E-GO II Button Receptors Replacement
  1. Doss E-GO II Button Receptors Replacement, Button Receptors: step 1, image 1 of 3 Doss E-GO II Button Receptors Replacement, Button Receptors: step 1, image 2 of 3 Doss E-GO II Button Receptors Replacement, Button Receptors: step 1, image 3 of 3
    • Peel the backing off of the speaker.
    • Remove eight 7.9 mm screws using the Phillips #00 screwdriver.
    • Gently pull apart the grille on the sides of the speaker.
  2. Doss E-GO II Button Receptors Replacement: step 2, image 1 of 2 Doss E-GO II Button Receptors Replacement: step 2, image 2 of 2
    • Remove seven 8 mm screws using a Phillips #00 screwdriver.
    • Remove six 7.3 mm screws using a Phillips #00 screwdriver.
  3. Doss E-GO II Button Receptors Replacement: step 3, image 1 of 3 Doss E-GO II Button Receptors Replacement: step 3, image 2 of 3 Doss E-GO II Button Receptors Replacement: step 3, image 3 of 3
    • Apply a bead of flux.
    • Press the soldering iron tip firmly to melt the solder.
    • If you heat the circuit board constantly for more than 10 seconds, the excessive heat may damage the board.
    • Use tweezers to remove the receptor.
  4. Doss E-GO II Button Receptors Replacement: step 4, image 1 of 1
    • Use a small piece of solder to attach a new receptor.
    • Press the tip 2 seconds on each corner to attach the receptor to the board.
Natalie
355 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 25
All Time: 183
