Up to 20% off select tools
Doorknob Privacy Pin Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
155
All Time:
1,155
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Whether your doorknob's privacy pin is broken, stuck, or simply missing, replacing it is a common home maintenance task that can restore security and functionality to your door.
This guide will quickly walk you through the simple steps to swap out that old pin for a new one. All you need is a screwdriver and a new door privacy pin.
    1. Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: step 1, image 1 of 3 Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: step 1, image 2 of 3 Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: step 1, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two screws holding the interior and exterior doorknob halves together.
      Ask FixBot
    2. Doorknob Privacy Pin Replacement: step 2, image 1 of 2 Doorknob Privacy Pin Replacement: step 2, image 2 of 2
      • Carefully pull the doorknob halves apart.
      • The spindle and the latch mechanism should now be accessible.
      Ask FixBot
    3. Doorknob Privacy Pin Replacement: step 3, image 1 of 3 Doorknob Privacy Pin Replacement: step 3, image 2 of 3 Doorknob Privacy Pin Replacement: step 3, image 3 of 3
      • Use the Phillips #1 screwdriver to remove the privacy pin.
      • It is a small, threaded pin that screws into a hole on the latch mechanism itself or on the interior doorknob assembly.
      Ask FixBot
    4. Doorknob Privacy Pin Replacement: step 4, image 1 of 1
      • Remove the old/ damaged privacy pin.
      Ask FixBot
    5. Doorknob Privacy Pin Replacement: step 5, image 1 of 3 Doorknob Privacy Pin Replacement: step 5, image 2 of 3 Doorknob Privacy Pin Replacement: step 5, image 3 of 3
      • Screw the new privacy pin into the corresponding hole.
      • Ensure it's securely tightened but don't overtighten, as this could strip the threads.
      Ask FixBot
    6. Doorknob Privacy Pin Replacement: step 6, image 1 of 3 Doorknob Privacy Pin Replacement: step 6, image 2 of 3 Doorknob Privacy Pin Replacement: step 6, image 3 of 3
      • Align the spindle with the latch mechanism, then bring the two doorknob halves back together.
      • Make sure all parts are properly seated.
      Ask FixBot
    7. Doorknob Privacy Pin Replacement: step 7, image 1 of 3 Doorknob Privacy Pin Replacement: step 7, image 2 of 3 Doorknob Privacy Pin Replacement: step 7, image 3 of 3
      • Securely fasten the two screws with the Phillips #1 screwdriver.
      • Snap or twist the decorative covers back into place (If applicable).
      • Test the privacy pin several times to ensure it engages and disengages smoothly.
      Ask FixBot
Author
with
Elias Moseri
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 155
All Time: 1,155
