Kindle 10 Display Assembly Replacement
  1. Kindle 10 Display Assembly Replacement, Display Assembly: step 1, image 1 of 3 Kindle 10 Display Assembly Replacement, Display Assembly: step 1, image 2 of 3 Kindle 10 Display Assembly Replacement, Display Assembly: step 1, image 3 of 3
    • Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
  2. Kindle 10 Display Assembly Replacement: step 2, image 1 of 1
    • Remove the eight 2.6 mm screws using a T5 Torx screwdriver.
  3. Kindle 10 Display Assembly Replacement: step 3, image 1 of 1
    • Remove the display assembly from the device.
hzheng2
537 Reputation
4 Guides authored
UMass Dartmouth, Team 1-2, Konn Fall 2024 Member of UMass Dartmouth, Team 1-2, Konn Fall 2024
UMASSD-KONN-F24S1G2
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 95
All Time: 749
