Introduction
A step-by-step guide to disconnecting the wiring attached to the screen of the Garmin Nuvi 680.
Flip open the antenna on the back of the device.
Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
Insert the pointed end of a spudger into the leftmost slit of the antenna case.
Push the spudger to the right.
Slide the antenna case out of the device.
Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
These screws are 10.82 mm long.
Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
Remove the antenna.
Lift the latches on the ribbon cable connectors. The rightmost cable does not have a latch.
Gently pull the ribbon cables out of their connectors. They should slide out easily.
Gently pull the cable for the on/off button straight up to remove it.
The two halves of the device may now be separated.
