Disconnect Left-Over Logic Board Connectors
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Disconnect Left-Over Logic Board Connectors, Disconnect the trackpad cable: step 1, image 1 of 2 Disconnect Left-Over Logic Board Connectors, Disconnect the trackpad cable: step 1, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
      • Remove the trackpad connector bracket.
      Ask FixBot
    2. Disconnect Left-Over Logic Board Connectors: step 2, image 1 of 2 Disconnect Left-Over Logic Board Connectors: step 2, image 2 of 2
      • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
      Ask FixBot
    3. Disconnect Left-Over Logic Board Connectors, Disconnect the audio board cable: step 3, image 1 of 3 Disconnect Left-Over Logic Board Connectors, Disconnect the audio board cable: step 3, image 2 of 3 Disconnect Left-Over Logic Board Connectors, Disconnect the audio board cable: step 3, image 3 of 3
      • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
      • Slide the sound board cable out of the ZIF connector.
      Ask FixBot
Adam O'Camb
225,561 Reputation
415 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 17
All Time: 216
