Introduction
These are instructions to disassemble the camera case so that internal components can be accessed.
This is a prerequisite guide for repairs to the Canon PowerShot A200.
Use the Phillips head screwdriver, rotating counterclockwise, to remove the two screws at the bottom of the camera. Set screws aside.
Hold the camera right side up with the LCD screen facing you. On the left edge of the camera there is one screw visible. There is also a rubber covering. Slide the rubber covering out of the way to expose another screw.
Use a Phillips head screwdriver, rotating counterclockwise, to remove both screws. Set the screws aside.
Hold the camera right side up with the LCD screen facing you. Open the battery compartment on the right side of the camera casing by pushing slightly in the direction of the arrow.
Use the Phillips head screwdriver, rotating counterclockwise, to remove the two screws on either side of the memory card slot. Set the screws aside.
Pull the grey tab towards the back of the camera. Lift the black section of the battery cover up, exposing the battery slots.
Use the Phillips head screwdriver, rotating counter clockwise to remove the two screws on either side of the battery slots. Set the screws aside.
Hold the camera right side up with the LCD screen facing you. Remove the screen battery located to the left of the screen. Set it aside.
On the front half of the camera, locate the black tabs on either side of the white ribbon.
Use the metal tweezers to gently move the black tabs to the outside edges of the ribbon.
Gently pull the white ribbon out of the connection.
On the front half of the camera, locate the black tabs on either side of the orange ribbon.
Gently pull the orange ribbon out of the connection.
Now that your camera is disassembled, you may follow the specific guide for repair or replacement of camera components.
To reassemble your camera, follow these instructions in reverse order.
