Shop the Holiday Gift Guide
Disassembling iPhone 4S Logic Board
Views: 3.5K
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
12
All Time:
3,469
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 31
31 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide has been updated by iFixit staff! Read the new, official guide here.
Tools
    1. Disassembling iPhone 4S Logic Board, Disassembling iPhone 4S Battery: step 1, image 1 of 1
      • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
      Ask FixBot
    2. Disassembling iPhone 4S Logic Board: step 2, image 1 of 1
      • Push the back glass towards the top of the phone.
      Ask FixBot
    3. Disassembling iPhone 4S Logic Board: step 3, image 1 of 1
      • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
      Ask FixBot
    4. Disassembling iPhone 4S Logic Board: step 4, image 1 of 2 Disassembling iPhone 4S Logic Board: step 4, image 2 of 2
      • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
      • Using a plastic opener tool, pry up the battery connector.
      Ask FixBot
    5. Disassembling iPhone 4S Logic Board: step 5, image 1 of 1
      • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
      • Then, out pops the battery.
      Ask FixBot
    1. Disassembling iPhone 4S Logic Board, Disassembling iPhone 4S Logic Board: step 6, image 1 of 1
      • Disconnect the antenna cable from the logic board.
      Ask FixBot
    2. Disassembling iPhone 4S Logic Board: step 7, image 1 of 1
      • Unscrew the 2 phillips screws holding the shield covering the dock connector ribbon.
      • One of the screws is .2 millimeters longer than the other.
      Ask FixBot
    3. Disassembling iPhone 4S Logic Board: step 8, image 1 of 2 Disassembling iPhone 4S Logic Board: step 8, image 2 of 2
      • Disconnect the dock connector ribbon from the logic board.
      • Pull the cable up and flow it to the side.
      Ask FixBot
    4. Disassembling iPhone 4S Logic Board: step 9, image 1 of 2 Disassembling iPhone 4S Logic Board: step 9, image 2 of 2
      • Unscrew the 4 screws holding the large shield and the single screw holding the small shield.
      Ask FixBot
    5. Disassembling iPhone 4S Logic Board: step 10, image 1 of 1
      • Using the plastic opening tool, pry up the 7 connectors on the top of the logic board.
      • The back camera will come out, make sure you get the small piece of black plastic covering the back of the camera.
      Ask FixBot
    6. Disassembling iPhone 4S Logic Board: step 11, image 1 of 2 Disassembling iPhone 4S Logic Board: step 11, image 2 of 2
      • Unscrew the 2 flat head screws.
      • Unscrew the 3 phillips head screws, the top one is covered by a small piece of black tape.
      Ask FixBot
    7. Disassembling iPhone 4S Logic Board: step 12, image 1 of 1
      • Using your fingers or a plastic opening tool carefully pull out the logic board.
      Ask FixBot
7 other people completed this guide.
Author
with
Chandler
3,710 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 3,469
