Disassembling front of the Panasonic SA-PM17
  1. Disassembling front of the Panasonic SA-PM17, Disassembling front of the Panasonic SA-PM17: step 1, image 1 of 2 Disassembling front of the Panasonic SA-PM17, Disassembling front of the Panasonic SA-PM17: step 1, image 2 of 2
    • Using a philips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device and place aside.
  2. Disassembling front of the Panasonic SA-PM17: step 2, image 1 of 1
    • Remove these seven 11.5 mm screws and place aside.
  3. Disassembling front of the Panasonic SA-PM17: step 3, image 1 of 1
    • Lift the right side off of the device and place aside.
    • Repeat for left side.
  4. Disassembling front of the Panasonic SA-PM17: step 4, image 1 of 1
    • Lift the top gently but firmly from the back of the device and allow to rest on the back without reattaching it.
    • CAUTION: Do not pull the top too far as there are wires attached to it.
  5. Disassembling front of the Panasonic SA-PM17: step 5, image 1 of 2 Disassembling front of the Panasonic SA-PM17: step 5, image 2 of 2
    • Lift up gently on the tabs indicated to disengage them from the hooks holding them in place.
  6. Disassembling front of the Panasonic SA-PM17: step 6, image 1 of 1
    • Lift up the top while firmly sliding it towards the back of the device.
    • CAUTION: Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
    • The next step is a zoom-in of the indicated area.
  7. Disassembling front of the Panasonic SA-PM17: step 7, image 1 of 1
    • Using forceps or fingers, remove the small black wire indicated.
    • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
  8. Disassembling front of the Panasonic SA-PM17: step 8, image 1 of 3 Disassembling front of the Panasonic SA-PM17: step 8, image 2 of 3 Disassembling front of the Panasonic SA-PM17: step 8, image 3 of 3
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near its base until it comes free of the restraint.
  9. Disassembling front of the Panasonic SA-PM17: step 9, image 1 of 3 Disassembling front of the Panasonic SA-PM17: step 9, image 2 of 3 Disassembling front of the Panasonic SA-PM17: step 9, image 3 of 3
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body. Place it aside in a safe place.
  10. Disassembling front of the Panasonic SA-PM17: step 10, image 1 of 3 Disassembling front of the Panasonic SA-PM17: step 10, image 2 of 3 Disassembling front of the Panasonic SA-PM17: step 10, image 3 of 3
    • This step deals with the indicated portion of the the device.
    • Lift the indicated tabs out until they look like the final picture.
    • Gently pull on the cord until it comes free of its restraint.
  11. Disassembling front of the Panasonic SA-PM17: step 11, image 1 of 3 Disassembling front of the Panasonic SA-PM17: step 11, image 2 of 3 Disassembling front of the Panasonic SA-PM17: step 11, image 3 of 3
    • Neither of the indicated cords have restraints on them like the previous ones. Simply use tweezers or fingers to pull firmly on the base of each cord until it comes free.
  12. Disassembling front of the Panasonic SA-PM17: step 12, image 1 of 2 Disassembling front of the Panasonic SA-PM17: step 12, image 2 of 2
    • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
  13. Disassembling front of the Panasonic SA-PM17: step 13, image 1 of 3 Disassembling front of the Panasonic SA-PM17: step 13, image 2 of 3 Disassembling front of the Panasonic SA-PM17: step 13, image 3 of 3
    • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
    • Rotate device 180 degrees and repeat for other side.
    • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
  14. Disassembling front of the Panasonic SA-PM17: step 14, image 1 of 1
    • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
NathanB
418 Reputation
5 Guides authored
Cal Poly, Team 4-1, Regan Spring 2011 Member of Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 4,343
