Disassembling Yoton Y3 Projector frame and components
    1. Disassembling Yoton Y3 Projector frame and components, frame and components: step 1, image 1 of 1
      • first, you will need to remove the two small screws that are next to each other on the bottom right.
      Ask FixBot
    2. Disassembling Yoton Y3 Projector frame and components: step 2, image 1 of 1
      • the next step is to remove the five sunk in screws, one of which is behind one of the feet, as you can see in the photo. You should be able to wiggle the top off at that point.
      Ask FixBot
    3. Disassembling Yoton Y3 Projector frame and components: step 3, image 1 of 1
      • after that, there are three screws that hold the motherboard in place that need to come out.
      • Once those are out, you want to disconnect the ribbon cable by flipping the black tab upwards and pulling the cable out once it's loose.
      • now what you can do is wiggle the board away from the frame in the direction of the projector lens, being careful not to tear any cables. There are two cables which are glued into place, but I was able to leave them in place, glue and all. Once the motherboard is out and able to move around, you can start to disassemble the frame below.
      Ask FixBot
    4. Disassembling Yoton Y3 Projector frame and components: step 4, image 1 of 1
      • unfortunately I forgot to take a picture of the frame before I got it out, but there are about four screws that you can remove from that black piece in the photo, and you don't need to remove the motherboard. You can work around it.
      • once the screws are out of the black frame, you can wiggle it out from its place, keeping in mind to unlatch the wires it is attached to. Once you do that, you are able to get access to the interior lenses for cleaning or removing.
      Ask FixBot
    5. Disassembling Yoton Y3 Projector frame and components: step 5, image 1 of 1
      • now you are able to access the mirrors, lenses, and other components for maintenance and cleaning.
      • follow the reverse of these steps to put it all back together.
      Ask FixBot
Daniel Schmidt
127 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 15
