Disassembling Unbranded Robot Vacuum (full disassembly)
    1. Disassembling Unbranded Robot Vacuum (full disassembly), Full disassembly: step 1, image 1 of 3 Disassembling Unbranded Robot Vacuum (full disassembly), Full disassembly: step 1, image 2 of 3 Disassembling Unbranded Robot Vacuum (full disassembly), Full disassembly: step 1, image 3 of 3
      • You will need a PH0 screwdriver.
      • First make sure the power is turned off. (this is the red switch on the bottom.)
      • This then can be followed by removing the side brush.
      Ask FixBot
    2. Disassembling Unbranded Robot Vacuum (full disassembly): step 2, image 1 of 2 Disassembling Unbranded Robot Vacuum (full disassembly): step 2, image 2 of 2
      • Next remove the screws connecting the top of the bumper to the bottom.
      • Then remove the top of the bumper. By lifting and pulling the plate towards yourself.
      Ask FixBot
    3. Disassembling Unbranded Robot Vacuum (full disassembly): step 3, image 1 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 3, image 2 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 3, image 3 of 3
      • Remove the top white plate.
      • Remove the fan housing part.
      • Remove the filter from the part by popping the lid off the part. (this can be done with your hands.)
      Ask FixBot
    4. Disassembling Unbranded Robot Vacuum (full disassembly): step 4, image 1 of 2 Disassembling Unbranded Robot Vacuum (full disassembly): step 4, image 2 of 2
      • After Unscrew the rest of the plates from the base.
      • Next remove the base from the top as shown. (make sure to be careful as the lid and the base are attached by a wire.
      Ask FixBot
    5. Disassembling Unbranded Robot Vacuum (full disassembly): step 5, image 1 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 5, image 2 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 5, image 3 of 3
      • Now unplug the battery.
      • After unplug all the components MAKING SURE TO KEEP TRACK OF WHAT GOES WHERE!
      • Once done unscrew the motors and remove them from the chasis.
      Ask FixBot
    6. Disassembling Unbranded Robot Vacuum (full disassembly): step 6, image 1 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 6, image 2 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 6, image 3 of 3
      • Now the motherboard must be removed. Unscrew the motherboard and remove so that other components can be removed.
      • Once removed all of the IR sensors can be removed.
      • Unscrew and remove the IR sensors followed by popping out the power switch (this will require some force.)
      Ask FixBot
    7. Disassembling Unbranded Robot Vacuum (full disassembly): step 7, image 1 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 7, image 2 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 7, image 3 of 3
      • Remove the IR sensors casing and place the 2 parts next to the IR sensors.
      • Next unscrew the universal directional wheel.
      • Next unscrew the lower bumper and remove it.
      Ask FixBot
    8. Disassembling Unbranded Robot Vacuum (full disassembly): step 8, image 1 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 8, image 2 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 8, image 3 of 3
      • Now unscrew the lower fan housing and remove.
      • Flip over the product and unscrew the back panel. Then remove the battery.
      Ask FixBot
    9. Disassembling Unbranded Robot Vacuum (full disassembly): step 9, image 1 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 9, image 2 of 3 Disassembling Unbranded Robot Vacuum (full disassembly): step 9, image 3 of 3
      • Sub assembly of Motor and Wheel.
      • First unscrew the wheel from the motor.
      • Next remove the tyre from the wheel.
      • After unscrew the motor and open it.
      Ask FixBot
    10. Disassembling Unbranded Robot Vacuum (full disassembly): step 10, image 1 of 2 Disassembling Unbranded Robot Vacuum (full disassembly): step 10, image 2 of 2
      • Disassembly of fan and holder.
      • First remove the fan. (This will require some force.)
      • Next unscrew the motor and remove.
      Ask FixBot
    11. Disassembling Unbranded Robot Vacuum (full disassembly): step 11, image 1 of 2 Disassembling Unbranded Robot Vacuum (full disassembly): step 11, image 2 of 2
      • Disassembly of lower bumper.
      • Unscrew the plates and remove.
      Ask FixBot
Jonty Bhumbra
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 194
All Time: 717
