Disassembling Trek 820 Tire Removal from Wheel
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Disassembling Trek 820 Tire Removal from Wheel, Tire Removal from Wheel: step 1, image 1 of 1
    • Locate the tire pressure valve.
  2. Disassembling Trek 820 Tire Removal from Wheel: step 2, image 1 of 1
    • First, you must release the air.
    • To release the air from the tire, press the center spoke in the middle of the air pressure valve.
    • Release air until no more air is being released.
  3. Disassembling Trek 820 Tire Removal from Wheel: step 3, image 1 of 2 Disassembling Trek 820 Tire Removal from Wheel: step 3, image 2 of 2
    • Use a sturdy, long object, such as a screwdriver or the back of a spoon, to wedge in between the tire and the wheel
  4. Disassembling Trek 820 Tire Removal from Wheel: step 4, image 1 of 3 Disassembling Trek 820 Tire Removal from Wheel: step 4, image 2 of 3 Disassembling Trek 820 Tire Removal from Wheel: step 4, image 3 of 3
    • Now you may separate the tire from the wheel.
    • Be careful pulling the tire from the wheel around the air pressure valve.
  5. Disassembling Trek 820 Tire Removal from Wheel: step 5, image 1 of 2 Disassembling Trek 820 Tire Removal from Wheel: step 5, image 2 of 2
    • To remove the tube, all you need to do is pull the tube from the inner lining of the tire.
Kaveh Karimiyanha
813 Reputation
7 Guides authored
Cal Poly, Team 1-1, Propen Fall 2012 Member of Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 1,139
