Disassembling Toshiba A1304T Front Cover
  1. Disassembling Toshiba A1304T Front Cover, Front Cover: step 1, image 1 of 1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Disassembling Toshiba A1304T Front Cover: step 2, image 1 of 2 Disassembling Toshiba A1304T Front Cover: step 2, image 2 of 2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Disassembling Toshiba A1304T Front Cover: step 3, image 1 of 2 Disassembling Toshiba A1304T Front Cover: step 3, image 2 of 2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
Christopher
90 Reputation
8 Guides authored
Cal Poly, Team 16-6, Maness Spring 2010 Member of Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Members
16 Guides authored
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 9
All Time: 2,116
