Disassembling Toshiba A1304T Back panel
  1. Disassembling Toshiba A1304T Back panel, Back panel: step 1, image 1 of 1
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Disassembling Toshiba A1304T Back panel: step 2, image 1 of 1
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
  3. Disassembling Toshiba A1304T Back panel: step 3, image 1 of 1
    • Lift the back panel off of the phone.
Christopher
90 Reputation
8 Guides authored
Cal Poly, Team 16-6, Maness Spring 2010 Member of Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 2,046
