Disassembling TDK Life on Record bottom panel
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Disassembling TDK Life on Record bottom panel, Disassembling TDK Life on Record bottom panel: step 1, image 1 of 1
      • Remove the four rubber feet of the device using a metal spudger.
      Ask FixBot
    2. Disassembling TDK Life on Record bottom panel: step 2, image 1 of 2 Disassembling TDK Life on Record bottom panel: step 2, image 2 of 2
      • Remove the four 9 mm Phillips #0 screws located under the feet of the device.
      • Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
      Ask FixBot
    3. Disassembling TDK Life on Record bottom panel: step 3, image 1 of 2 Disassembling TDK Life on Record bottom panel: step 3, image 2 of 2
      • Pull the bottom cover of the device towards you.
      Ask FixBot
    4. Disassembling TDK Life on Record bottom panel: step 4, image 1 of 2 Disassembling TDK Life on Record bottom panel: step 4, image 2 of 2
      • Remove the four 13 mm Phillips #1 screws.
      Ask FixBot
    5. Disassembling TDK Life on Record bottom panel: step 5, image 1 of 2 Disassembling TDK Life on Record bottom panel: step 5, image 2 of 2
      • Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
      • The woofer is the circular component located at the bottom of the device after the bottom cover has been removed
      • Pull apart the compartments by applying force in opposite directions.
      • Do not pull with extreme force!! There are many electrical wires inside the device that can become damaged if the bottom panel is removed without care
      Ask FixBot
    6. Disassembling TDK Life on Record bottom panel: step 6, image 1 of 1
      • Disconnect the seven cables attached to the motherboard.
      • Do not use too much force when pulling on the wires. Pulling with too much force can damage the wires.
      Ask FixBot
Eduardo Barrios
359 Reputation
2 Guides authored
CSU Fullerton, Team 1-2, Bruce Fall 2015 Member of CSU Fullerton, Team 1-2, Bruce Fall 2015
CSUF-BRUCE-F15S1G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 155
