Shop the Holiday Gift Guide
Disassembling Sony Xperia J External Features
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
2
All Time:
205
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite Only
Tools
    1. Disassembling Sony Xperia J External Features, External Features: step 1, image 1 of 1
      • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
      Ask FixBot
    2. Disassembling Sony Xperia J External Features: step 2, image 1 of 1
      • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
      Ask FixBot
    3. Disassembling Sony Xperia J External Features: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
      Ask FixBot
    4. Disassembling Sony Xperia J External Features: step 4, image 1 of 3 Disassembling Sony Xperia J External Features: step 4, image 2 of 3 Disassembling Sony Xperia J External Features: step 4, image 3 of 3
      • Using the Torx T5 screwdriver remove the four 4.74mm screws.
      • Then remove the two 3.13mm screws
      • Lastly remove 5.90mm screw.
      Ask FixBot
    5. Disassembling Sony Xperia J External Features: step 5, image 1 of 3 Disassembling Sony Xperia J External Features: step 5, image 2 of 3 Disassembling Sony Xperia J External Features: step 5, image 3 of 3
      • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
      • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
      Ask FixBot
    6. Disassembling Sony Xperia J External Features: step 6, image 1 of 1
      • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
      Ask FixBot
    7. Disassembling Sony Xperia J External Features: step 7, image 1 of 1
      • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
      Ask FixBot
Author
with
Andres Pico
276 Reputation
1 Guide authored
USF Tampa, Team 4-3, Brown Winter 2015 Member of USF Tampa, Team 4-3, Brown Winter 2015
USFT-BROWN-W15S4G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 205
