Shop the Holiday Gift Guide
Disassembling Sony Ericsson W200i Core
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
5
All Time:
807
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Removing the core is easy, but you will be removing 4 screws, so make sure you have a place to put them for safe-keeping.
Tools
    1. Disassembling Sony Ericsson W200i Core, Disassembling Sony Ericsson W200i Battery: step 1, image 1 of 2 Disassembling Sony Ericsson W200i Core, Disassembling Sony Ericsson W200i Battery: step 1, image 2 of 2
      • Slide the battery cover up and off the phone.
      Ask FixBot
    2. Disassembling Sony Ericsson W200i Core: step 2, image 1 of 2 Disassembling Sony Ericsson W200i Core: step 2, image 2 of 2
      • Pop the battery out of its slot by lifting it up.
      Ask FixBot
    1. Disassembling Sony Ericsson W200i Core, Front Case: step 3, image 1 of 3 Disassembling Sony Ericsson W200i Core, Front Case: step 3, image 2 of 3 Disassembling Sony Ericsson W200i Core, Front Case: step 3, image 3 of 3
      • Insert the plastic opening tool in between the front case and the back case.
      • Apply downward pressure to make the case lift upwards, thus popping the front case off.
      • Use caution when removing the front case. It may seem stuck but just ease it out.
      Ask FixBot
    1. Disassembling Sony Ericsson W200i Core, Core: step 4, image 1 of 2 Disassembling Sony Ericsson W200i Core, Core: step 4, image 2 of 2
      • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
      • Note that the top 2 screws are silver and the bottom 2 screws are black.
      Ask FixBot
    2. Disassembling Sony Ericsson W200i Core: step 5, image 1 of 3 Disassembling Sony Ericsson W200i Core: step 5, image 2 of 3 Disassembling Sony Ericsson W200i Core: step 5, image 3 of 3
      • There is a black tab in the top left corner holding the core in place.
      • Remove the core by pulling straight up to prevent breaking the tab.
      Ask FixBot
Author
with
Emily Prescott
531 Reputation
4 Guides authored
Cal Poly, Team 14-10, Forte Winter 2011 Member of Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 807
