Snapfon ez One SIM Card Replacement
  1. Snapfon ez One SIM Card Replacement, Remove the battery cover: step 1, image 1 of 1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One SIM Card Replacement, Remove the battery: step 2, image 1 of 1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One SIM Card Replacement, SIM Card: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
John Bender
818 Reputation
8 Guides authored
Clemson, Team 6-5, Benson Spring 2014 Member of Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 11
All Time: 1,280
