Disassembling Sanyo Katana Eclipse X Outer Casing
  1. Disassembling Sanyo Katana Eclipse X Outer Casing, Back Panel: step 1, image 1 of 2 Disassembling Sanyo Katana Eclipse X Outer Casing, Back Panel: step 1, image 2 of 2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Disassembling Sanyo Katana Eclipse X Outer Casing: step 2, image 1 of 1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Disassembling Sanyo Katana Eclipse X Outer Casing, Disassembling Sanyo Katana Eclipse X Outer Casing: step 3, image 1 of 1
    • This task can be difficult. This phone has several specialized screws that are engineered to prevent removal.
    • With the battery removed, four (5.75mm) screws that hold the outer case together are visible (circled in picture).
  4. Disassembling Sanyo Katana Eclipse X Outer Casing: step 4, image 1 of 1
    • Using your "Damaged Screw Remover", remove the screws from their current positions.
    • Once the screws are removed, the phone can be split apart.
    • You may need to wiggle the case a bit in order to get it loose
    • The case is now open.
Scott Kelley
101 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 479
