Disassembling ProtoArc EM01 NL
Views: 1.6K
View statistics:
Past 24 Hours:
11
Past 7 Days:
55
Past 30 Days:
267
All Time:
1,590
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Disassembling ProtoArc EM01 NL, Remove Rocker Plate: step 1, image 1 of 2 Disassembling ProtoArc EM01 NL, Remove Rocker Plate: step 1, image 2 of 2
      • Push the pins inward, ONE side at a time, then lift the side from the bottom of the main body, to free it from socket. Then take care of the other side.
      • The pins
      • The socket
      • Be aware, there are 2 strong magnets.
      • This is the most difficult part. Take your time.
      Ask FixBot
    2. Disassembling ProtoArc EM01 NL, Open Main Body: step 2, image 1 of 2 Disassembling ProtoArc EM01 NL, Open Main Body: step 2, image 2 of 2
      • Remove the track ball (THE ball itself)
      • Remove 6 self-tap screws. The one pointed by an arrow needs a long thin philip head screw driver
      • Apply a little bit prying force bear the ball socket, to open the bottom.
      • Not so fast! Watch out for the FPC! Read next step first!
      Ask FixBot
    3. Disassembling ProtoArc EM01 NL, Unplug the FPC: step 3, image 1 of 1
      • Unlatch the FPC connector by:
      • Push the black plastic latch up. Using tweezers.
      • Pull out the top cover FPC.
      • If possible, unplug the battery first.
      Ask FixBot
    4. Disassembling ProtoArc EM01 NL, Open the Top Case: step 4, image 1 of 2 Disassembling ProtoArc EM01 NL, Open the Top Case: step 4, image 2 of 2
      • Now separate top and bottom case.
      Ask FixBot
    5. Disassembling ProtoArc EM01 NL, Remove the Ring: step 5, image 1 of 2 Disassembling ProtoArc EM01 NL, Remove the Ring: step 5, image 2 of 2
      • Remove the ring from ball socket
      • There's a notch and a pair of keys. Should align them when assembling back.
      Ask FixBot
    6. Disassembling ProtoArc EM01 NL, Button Daughterboard: step 6, image 1 of 2 Disassembling ProtoArc EM01 NL, Button Daughterboard: step 6, image 2 of 2
      • Unplug the battery, as early as possible!!
      • Remove 1 self-tap screw
      • Lift the tiny PCB witth 2 buttons
      Ask FixBot
    7. Disassembling ProtoArc EM01 NL, Tracking sensor (Optional): step 7, image 1 of 1
      • Same type FPC connector. Handle it as before. But, there's a drop of glue, removing it might damage the connector and/or the cable. Skip this if not intent to replace the tracking sensor.
      Ask FixBot
    8. Disassembling ProtoArc EM01 NL, Main PCB with Sensor: step 8, image 1 of 2 Disassembling ProtoArc EM01 NL, Main PCB with Sensor: step 8, image 2 of 2
      • To remove battery, remove 2 screws. (optional)
      • Remove 4 screws for the PCB
      • Remove 2 screws for the sensor
      • Lift main PCB and the sensor module (ball socket) off the bottom case.
      Ask FixBot
    9. Disassembling ProtoArc EM01 NL, Type-C Module: step 9, image 1 of 2 Disassembling ProtoArc EM01 NL, Type-C Module: step 9, image 2 of 2
      • Noticed the 4-pin socket? There is a 4-pin pinheader under main PCB mating with it. should plug them back together while reassembling. Sorry for the shallow DOF, shot really close up and under poor lighting.
      • Remove 2 screws. Then remove the type-C module.
      Ask FixBot
    10. Disassembling ProtoArc EM01 NL, The Wheel: step 10, image 1 of 1
      • Remove the wheel from rotation encoder
      Ask FixBot
    11. Disassembling ProtoArc EM01 NL, Replace the Button Switch: step 11, image 1 of 3 Disassembling ProtoArc EM01 NL, Replace the Button Switch: step 11, image 2 of 3 Disassembling ProtoArc EM01 NL, Replace the Button Switch: step 11, image 3 of 3
      • Possibly exactly why you need this guide for.
      • Original switch is silent 2-pin square type. It's totally interchangable with common 3-pin mouse switches (Omron D2F type).
      Ask FixBot
    12. Disassembling ProtoArc EM01 NL, More Detail of the Switch Comparison: step 12, image 1 of 1
      • See? same hight. Also same pin pitch.
      Ask FixBot
Terrance
7,099 Reputation
19 Guides authored
1 Guide Comment
Nice guide! I wish we had more information about the encoder so we could replace it. Do you know the exact size to buy?
Paulo César - Reply Share
Past 24 Hours: 11
Past 7 Days: 55
Past 30 Days: 267
All Time: 1,590
