Power Mac G4 M5183 Processor Replacement
  1. Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Processor Replacement, Heat Sink: step 2, image 1 of 2 Power Mac G4 M5183 Processor Replacement, Heat Sink: step 2, image 2 of 2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Processor Replacement: step 3, image 1 of 1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Processor Replacement, Processor: step 4, image 1 of 2 Power Mac G4 M5183 Processor Replacement, Processor: step 4, image 2 of 2
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
Finish Line
13 other people completed this guide.
Justin Petrilli
3,132 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
37 Guides authored
2 Guide Comments
anyone still sell the replacement processor?
Joseph Cole - Reply
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 20
All Time: 12,565
