Introduction
How to replace the LCD screen if it is broken or cracked.
  1. Locate the battery cover on the bottom of the camera.
    • Locate the battery cover on the bottom of the camera.
  2. Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  3. Remove the batteries from the camera.
    • Remove the batteries from the camera.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
    • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  6. Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  7. Locate the black plastic strip under the screen above the white plastic strip.
    • Locate the black plastic strip under the screen above the white plastic strip.
  8. Pull up both sides of the black piece up about a mm.
    • Pull up both sides of the black piece up about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
Dani
21 Reputation
7 Guides authored
Cal Poly, Team 3-3, Johann Summer 2010 Member of Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,521
