Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide)
Video Overview
  1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: step 1, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: step 1, image 2 of 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 2, image 1 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 2, image 2 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 2, image 3 of 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 3, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 3, image 2 of 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 4, image 1 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 4, image 2 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 4, image 3 of 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 5, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 5, image 2 of 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 6, image 1 of 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 7, image 1 of 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 8, image 1 of 1
    • Separate the front and rear cases.
  9. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: step 9, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: step 9, image 2 of 2
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 10, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 10, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 11, image 1 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 11, image 2 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 11, image 3 of 3
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
6 other people completed this guide.
djgodmandj
284 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 35
All Time: 5,695
