Shop the Holiday Gift Guide
Disassembling Philips QG3040 Case
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
89
All Time:
1,187
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
You will actually break parts of housing!
But as you can change the battery you make the trimmer last longer.
Tools
      • The following 5 bullets are a citation of the User Manual (you can find it at philips.com):
      • Removing the rechargeable battery Only remove the rechargeable battery when it is completely empty.
      • 1 Disconnect the appliance from the mains and let the appliance run until the motor stops.
      • 2 Remove any comb and/or attachment from the appliance.
      • 3 Insert a screwdriver in the groove next to the shaft at the top of the appliance.Turn the screwdriver to separate the two housing halves (Fig. 22).
      • 4 Lift the battery out of the housing with a screwdriver. Twist the connecting wires until they break (Fig. 23).
      • Comment: the two mentioned figures are not very useful. You can start disassembling even with your fingers (start at the top). In the middle you will need the screw driver and there will break some plastic clips.
      Ask FixBot
To reassemble your device, you will probably need some tape because of the broken clips.
Author
with
sobotkasc
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 89
All Time: 1,187
