Disassembling Optoma HD20 Cover
  1. Disassembling Optoma HD20 Cover, Cover: step 1, image 1 of 2 Disassembling Optoma HD20 Cover, Cover: step 1, image 2 of 2
    • Twist focal cap clockwise until it is fully extended.
    • Remove focal cap by pulling it straight out.
  2. Disassembling Optoma HD20 Cover: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Disassembling Optoma HD20 Cover: step 3, image 1 of 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Disassembling Optoma HD20 Cover: step 4, image 1 of 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
Trever
1,264 Reputation
6 Guides authored
Cal Poly, Team 21-23, Maness Winter 2015 Member of Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 3,074
