Introduction
Follow these instructions to learn how to remove the Olympus Stylus Tough-8010 camera's casing.
Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
Take off smaller front cover.
Carefully remove larger front cover.
Remove two screws (4.1mm) on the top of the camera using a #000 Phillips head screwdriver.
Using a #000 Phillips head screwdriver remove two screws (7.9mm) near the control panel and set aside the metal connector.
Using a #000 Philips head screwdriver remove the two screws (4.1mm) on the right side of the camera.
Remove two screws (4.1mm) on the bottom of the camera using a #000 head Phillips screwdriver.
Remove the single screw (3.2mm) on the front of the camera using a #000 Phillips head.
Carefully remove the font panel piece from the rest of the camera.
Carefully remove the top/side plastic piece.
Remove four screws (9.4mm) on the front of the camera using a Phillips #000
Use the plastic opening tool to release the holding clip.
Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
