Remove the five Phillips #00 bottom and right side panel screws.
Remove the right side panel by pulling off the large silver piece.
There is no reference to removing screws from the right side panel, where it is necessary to remove 2 screws to do so.
Remove the three Phillips #00 screws from the front of the camera.
Using a spudger, lift the two tabs to separate the caseāone tab on top and one tab on the right side.
Wrong point of focus for the second picture. What should be in focus is very blurry.
Using a plastic spudger, lift up the black clips.
Still using the plastic spudger, detach the gold connector strip and white connector strip.
Using both hands, pull the camera apart into two pieces.
There were multiple gold strips, so the one that needs to be pulled should be highlited in the picture.
in step seven pull up the black bar of the ZIF connectors before pulling out the white or gold ribbons
Put a notice on here that the screws are very small and are easy to misplace while disassembling device. Also, while disassembling the device there was only one screw present, where the guide suggested there were three.
Curtis Reedy - Reply
Before beginning, put a note that the camera should be turned off before proceeding.
Add a note at the beginning of the guide that there are a large number of small screws that should be separated as the steps are completed.
There's a capacitor .....watch out for it in every step.
BILL BOYD - Reply
