Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017)
View statistics:
Past 24 Hours:
6
Past 7 Days:
47
Past 30 Days:
178
All Time:
927
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide is for the disassembly of the Nvidia Shield Remote (2017) which was included with the Gen 2 Nvidia Shield TV and Nvidia Shield TV Pro. This version of the remote does not have a headphone jack or rechargeable battery and uses 2032 button-cell batteries for power.
For the original Nvidia Shield Remote (2015), with rechargeable battery and headphone jack, use this guide instead.
This disassembly video also generally covers these steps:
https://www.youtube.com/watch?v=zvnzMZU1...
Tools
    1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: step 1, image 1 of 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: step 1, image 2 of 2
      • Plastic spudgers/opening tools
      • T2 Torx Screwdriver
      Ask FixBot
    2. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the battery compartment: step 2, image 1 of 1
      • Use a narrow-tipped object (such as a ballpoint pen or the tip of the T2 Torx Screwdriver) to depress the dimple on the battery compartment to release it
      • Replacement batteries are two (2) CR 2032 coin cell batteries.
      Ask FixBot
    3. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: step 3, image 1 of 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: step 3, image 2 of 2
      • Gently pry along the edges of the remote using your fingers and prying tools to release the plastic clips.
      • It works best to start from the battery compartment and slowly work your way up to the top of the remote where the IR blaster is located.
      • Once the plastic clips are released, there is adhesive along the length of the volume sensor bar holding the front face in place. Slowly pry the face away from the rest of the remote and adjust your grip to avoid snapping the thin plastic face.
      Ask FixBot
    4. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: step 4, image 1 of 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: step 4, image 2 of 2
      • There are (6) T2 Torx screws holding the mainboard to the frame of the remote.
      • Two clips hold the mainboard in place. Slightly lift the top of the mainboard up and slide it towards the top of the remote to remove it from the frame.
      Ask FixBot
    5. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: step 5, image 1 of 2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: step 5, image 2 of 2
      • The remote should now be fully disassembled.
      Ask FixBot
Skeven
152 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 47
Past 30 Days: 178
All Time: 927
