Nokia 6310i Speaker Replacement
  1. Nokia 6310i Speaker Replacement, Battery: step 1, image 1 of 2 Nokia 6310i Speaker Replacement, Battery: step 1, image 2 of 2
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Nokia 6310i Speaker Replacement, SIM card: step 2, image 1 of 3 Nokia 6310i Speaker Replacement, SIM card: step 2, image 2 of 3 Nokia 6310i Speaker Replacement, SIM card: step 2, image 3 of 3
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Nokia 6310i Speaker Replacement, Back Cover: step 3, image 1 of 1
    • Unscrew and remove the four T6 Torx screws.
  4. Nokia 6310i Speaker Replacement: step 4, image 1 of 3 Nokia 6310i Speaker Replacement: step 4, image 2 of 3 Nokia 6310i Speaker Replacement: step 4, image 3 of 3
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Nokia 6310i Speaker Replacement: step 5, image 1 of 3 Nokia 6310i Speaker Replacement: step 5, image 2 of 3 Nokia 6310i Speaker Replacement: step 5, image 3 of 3
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  6. Nokia 6310i Speaker Replacement, Antenna: step 6, image 1 of 2 Nokia 6310i Speaker Replacement, Antenna: step 6, image 2 of 2
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
  7. Nokia 6310i Speaker Replacement, Motherboard: step 7, image 1 of 1
    • Lift off the motherboard from the faceplate.
  8. Nokia 6310i Speaker Replacement, Speaker: step 8, image 1 of 2 Nokia 6310i Speaker Replacement, Speaker: step 8, image 2 of 2
    • Gently pop out the golden spring in the middle of the speaker. It should come out with little force.
3 other people completed this guide.
Mustafa
175 Reputation
4 Guides authored
Cal Poly, Team 14-41, Forte Fall 2010 Member of Cal Poly, Team 14-41, Forte Fall 2010
CPSU-FORTE-F10S14G41
5 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 48
All Time: 5,438
