Nokia 6086 Battery Replacement
  1. Nokia 6086 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Battery Replacement: step 2, image 1 of 3 Nokia 6086 Battery Replacement: step 2, image 2 of 3 Nokia 6086 Battery Replacement: step 2, image 3 of 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Battery Replacement: step 3, image 1 of 3 Nokia 6086 Battery Replacement: step 3, image 2 of 3 Nokia 6086 Battery Replacement: step 3, image 3 of 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
Andrea
70 Reputation
5 Guides authored
Cal Poly, Team 26-30, Regan Spring 2010 Member of Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 37
All Time: 4,044
