Disassembling Nokia 3395 Inner Components
  1. Disassembling Nokia 3395 Inner Components, Back Case: step 1, image 1 of 3 Disassembling Nokia 3395 Inner Components, Back Case: step 1, image 2 of 3 Disassembling Nokia 3395 Inner Components, Back Case: step 1, image 3 of 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Inner Components, Battery: step 2, image 1 of 2 Disassembling Nokia 3395 Inner Components, Battery: step 2, image 2 of 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Inner Components, Front Case: step 3, image 1 of 2 Disassembling Nokia 3395 Inner Components, Front Case: step 3, image 2 of 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Inner Components, Screen: step 4, image 1 of 2 Disassembling Nokia 3395 Inner Components, Screen: step 4, image 2 of 2
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Inner Components: step 5, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 5, image 2 of 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Inner Components, Logic Board: step 6, image 1 of 2 Disassembling Nokia 3395 Inner Components, Logic Board: step 6, image 2 of 2
    • Remove logic board as shown.
  7. Disassembling Nokia 3395 Inner Components, Inner Components: step 7, image 1 of 1
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
  8. Disassembling Nokia 3395 Inner Components: step 8, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 8, image 2 of 2
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
  9. Disassembling Nokia 3395 Inner Components: step 9, image 1 of 1
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
  10. Disassembling Nokia 3395 Inner Components: step 10, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 10, image 2 of 2
    • Audio speaker.
  11. Disassembling Nokia 3395 Inner Components: step 11, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 11, image 2 of 2
    • SIM card reader.
  12. Disassembling Nokia 3395 Inner Components: step 12, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 12, image 2 of 2
    • Vibrating unit.
  13. Disassembling Nokia 3395 Inner Components: step 13, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 13, image 2 of 2
  14. Disassembling Nokia 3395 Inner Components: step 14, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 14, image 2 of 2
Nico Lee
83 Reputation
6 Guides authored
Cal Poly, Team 30-41, Garner Spring 2010 Member of Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 3,076
