Disassembling Nokia 1110i (RH-93) made in Hongrie
  1. Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: step 1, image 1 of 3 Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: step 1, image 2 of 3 Disassembling Nokia 1110i (RH-93) made in Hongrie, Disassembling Nokia 1110i (RH-93) made in Hongrie: step 1, image 3 of 3
    • Switch off the device to avoid shocks while disassembling.
    • Turn the device face down and press on the small button at the bottom . Slide the back case down.
    • To remove the battery, use your finger to insert it in the groove and pull the battery out.
  2. Disassembling Nokia 1110i (RH-93) made in Hongrie: step 2, image 1 of 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: step 2, image 2 of 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: step 2, image 3 of 3
    • To remove the protective cover, use the tool shown and press the grey button at the left bottom.
    • The front cover ejects as shown. Remove it carefully to avoid damage.
    • The keypad case can be removed easily. Pull it up off the device.
    • Use a T6 Torx screwdriver to remove the screws.
  3. Disassembling Nokia 1110i (RH-93) made in Hongrie: step 3, image 1 of 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: step 3, image 2 of 3 Disassembling Nokia 1110i (RH-93) made in Hongrie: step 3, image 3 of 3
    • Find this channel at the top of your device.
    • Use a pair of tweezers to remove it carefully without harming the surroundings.
    • Insert the spudger into the section to remove the module.
  4. Disassembling Nokia 1110i (RH-93) made in Hongrie: step 4, image 1 of 2 Disassembling Nokia 1110i (RH-93) made in Hongrie: step 4, image 2 of 2
    • Use the spudger to remove the module casing safely.
    • Your device is successfully disassembled.
13 other people completed this guide.
JDU TV
3,063 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 3,600
