Disassembling Nintendo DS Lite Bottom Case
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Disassembling Nintendo DS Lite Bottom Case, Nintendo DS Lite Battery Disconnect: step 1, image 1 of 1
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
  2. Disassembling Nintendo DS Lite Bottom Case: step 2, image 1 of 1
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
  3. Disassembling Nintendo DS Lite Bottom Case: step 3, image 1 of 2 Disassembling Nintendo DS Lite Bottom Case: step 3, image 2 of 2
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
  4. Disassembling Nintendo DS Lite Bottom Case, Bottom Case: step 4, image 1 of 1
    • Remove the following 7 screws securing the lower case to the DS Lite:
    • 3 silver tri-wing screws (5mm long)
    • 1 black tri-wing screw (4mm)
    • 2 gold Phillips screws (4mm)
    • 1 silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
  5. Disassembling Nintendo DS Lite Bottom Case: step 5, image 1 of 1
    • Remove the plastic insert (or cartridge) from the lower slot (Slot 2).
  6. Disassembling Nintendo DS Lite Bottom Case: step 6, image 1 of 2 Disassembling Nintendo DS Lite Bottom Case: step 6, image 2 of 2
    • Flip the unit over.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they pop off easily and are difficult to reassemble. Keeping the bottom case against your workbench will help hold them in place.
  7. Disassembling Nintendo DS Lite Bottom Case: step 7, image 1 of 3 Disassembling Nintendo DS Lite Bottom Case: step 7, image 2 of 3 Disassembling Nintendo DS Lite Bottom Case: step 7, image 3 of 3
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power switch cover on the bottom case is in the off (down) position. Otherwise, the power switch cover can break the very fragile power switch upon reassembly.
Brittany K
1,493 Reputation
4 Guides authored
Cal Poly, Team 16-30, Maness Winter 2010 Member of Cal Poly, Team 16-30, Maness Winter 2010
CPSU-MANESS-W10S16G30
4 Members
25 Guides authored
Past 24 Hours: 14
Past 7 Days: 62
Past 30 Days: 248
All Time: 14,048
