Disassembling Nest Dropcam Pro Outer Case
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Disassembling Nest Dropcam Pro Outer Case, Outer Case: step 1, image 1 of 1
      • Press in the mounting clips on each side of the case to remove the camera from the mount.
      Ask FixBot
    2. Disassembling Nest Dropcam Pro Outer Case: step 2, image 1 of 2 Disassembling Nest Dropcam Pro Outer Case: step 2, image 2 of 2
      • Using a Philips #0 screwdriver, remove the four 3 mm screws.
      Ask FixBot
    3. Disassembling Nest Dropcam Pro Outer Case: step 3, image 1 of 2 Disassembling Nest Dropcam Pro Outer Case: step 3, image 2 of 2
      • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
      • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
      Ask FixBot
David Foens
914 Reputation
6 Guides authored
USF Tampa, Team 15-4, Blackwell Fall 2015 Member of USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 240
