Shop the Holiday Gift Guide
Disassembling Nerf Vortex Vigilon Inner Mechanism
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
6
All Time:
303
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the inner mechanism's screws: step 1, image 1 of 1
      • Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
      • Remove the #00 1.2 cm Phillips screw located to the right of the white casing.
      Ask FixBot
    2. Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the front cover: step 2, image 1 of 3 Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the front cover: step 2, image 2 of 3 Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the front cover: step 2, image 3 of 3
      • An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already.
      • Wiggle the front cover out from under the white piece and lift up from the gun.
      • Pulling the cover off is tricky due to its inner fitting.
      • Be sure to replace the orange block, spring, and clip before this step in reassembly.
      Ask FixBot
    3. Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the inner mechanism: step 3, image 1 of 1
      • The spring, cap, and rotating lever will likely fall out as you remove the inner mechanism.
      • Disconnect the inner mechanism from the outer cover by lifting the inner mechanism towards you.
      • Be sure to replace the spring, cap, and rotating lever before this step in reassembly.
      Ask FixBot
Author
with
Cara Pew
932 Reputation
7 Guides authored
Cal Poly, Team 13-6, Forte Fall 2014 Member of Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 303
