In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Introduction
Go to step 1 ↓This disassembly guide takes you through the MP-01 by the Minimal Company
It's not possible to disassemble the phone through the approach from the back.
A heat pad is recommended for weakening the glue.
Use a suction cup and thin spudger to separate the back. The back is ultra thin plastic, so be gentle with it.
The camera in this housing is loose. The rattle of the front and rear camera, coupled with the line in the screen prompted initial disassembly. Fix the rattle by using a piece of double sided-adhesive tape when you place the camera back in its housing.
If your disassembly goes anything like this, there is a TON of glue. Recommend cleaning using adhesive remover and reapply T-7000 as needed.
Remove bottom two screws. Annoyingly these use a different bit.
there are 5 screws that attach the assay to the board
