Disassembling Microtek ScanMaker 5900 Motor Tread
  1. Disassembling Microtek ScanMaker 5900 Motor Tread, Remove serial port connection: step 1, image 1 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Remove serial port connection: step 1, image 2 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Remove serial port connection: step 1, image 3 of 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Disassembling Microtek ScanMaker 5900 Motor Tread, Remove Lid: step 2, image 1 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Remove Lid: step 2, image 2 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Remove Lid: step 2, image 3 of 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Disassembling Microtek ScanMaker 5900 Motor Tread, Detach plastic latches: step 3, image 1 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Detach plastic latches: step 3, image 2 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Detach plastic latches: step 3, image 3 of 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Disassembling Microtek ScanMaker 5900 Motor Tread, Continue latch detachment: step 4, image 1 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Continue latch detachment: step 4, image 2 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Continue latch detachment: step 4, image 3 of 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Disassembling Microtek ScanMaker 5900 Motor Tread, Fully remove the upper lid: step 5, image 1 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Fully remove the upper lid: step 5, image 2 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread, Fully remove the upper lid: step 5, image 3 of 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Disassembling Microtek ScanMaker 5900 Motor Tread, Stepper Motor: step 6, image 1 of 2 Disassembling Microtek ScanMaker 5900 Motor Tread, Stepper Motor: step 6, image 2 of 2
    • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
    • Disconnect the white connector from the vertical standing circuit board.
  7. Disassembling Microtek ScanMaker 5900 Motor Tread: step 7, image 1 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread: step 7, image 2 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread: step 7, image 3 of 3
    • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
    • The stepper motor will become loose, but not completely free.
  8. Disassembling Microtek ScanMaker 5900 Motor Tread: step 8, image 1 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread: step 8, image 2 of 3 Disassembling Microtek ScanMaker 5900 Motor Tread: step 8, image 3 of 3
    • Using tweezers gently remove the tread from the black gear on the stepper motor.
    • The stepper motor will become completely free.
  9. Disassembling Microtek ScanMaker 5900 Motor Tread, Motor Tread: step 9, image 1 of 2 Disassembling Microtek ScanMaker 5900 Motor Tread, Motor Tread: step 9, image 2 of 2
    • Facing the front of the scanner you will see a white plastic wheel holding the other end of the tread.
    • Pull the spring towards you until it snaps off the side wall releasing the tension in the spring.
    • Using a #2 Philips Screwdriver, unscrew the single 5.88mm screw holding the mount of the plastic wheel in place.
  10. Disassembling Microtek ScanMaker 5900 Motor Tread: step 10, image 1 of 1
    • The plastic wheel and it's mount will be loose.
    • Remove the shaft holding the plastic wheel and the mount together
    • The tread will be completely loose.
Steven Shaginyan
39 Reputation
4 Guides authored
Cal Poly, Team 6-9, Regan Fall 2011 Member of Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Members
22 Guides authored
Past 24 Hours: 5
Past 7 Days: 6
Past 30 Days: 6
All Time: 1,346
