Introduction
With this guide you can take your MM-4 from one solid brick of a speaker to four parts and a bunch of screws. This is useful if you are replacing a bad driver, or if the connector becomes damaged and you need to replace it.
Turn the speaker face down, so the connector side is up.
Remove the four #2 Philips screws on the back plate.
Turn the speaker so the grill side is up.
Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
The grill is not glued on, but may require a bit of prying to remove.
Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
