Disassembling Mercedes W123 Glove Box Liner
  1. Disassembling Mercedes W123 Glove Box Liner, Glove Box Liner: step 1, image 1 of 1
    • Start by opening the glove box.
  2. Disassembling Mercedes W123 Glove Box Liner: step 2, image 1 of 2 Disassembling Mercedes W123 Glove Box Liner: step 2, image 2 of 2
    • Remove the two phillips screws in the glove box door catch, then remove it.
  3. Disassembling Mercedes W123 Glove Box Liner: step 3, image 1 of 2 Disassembling Mercedes W123 Glove Box Liner: step 3, image 2 of 2
    • Gently pry apart the expansion plug in the glove box clips. There will be a row of them on top, and on the bottom.
    • Once you've pried it out part of the way you can pull it the rest of the way out by hand, or gently with needle nose pliers.
  4. Disassembling Mercedes W123 Glove Box Liner: step 4, image 1 of 1
    • You can then pry the clips out of the liner. Remove them all.
  5. Disassembling Mercedes W123 Glove Box Liner: step 5, image 1 of 1
    • Gently pry down the cover for the glove box lamp.
  6. Disassembling Mercedes W123 Glove Box Liner: step 6, image 1 of 1
    • Now unplug the two connections from the lamp and remove the lamp housing.
    • Be sure to make note of the orientation of the two wires for re-installation.
  7. Disassembling Mercedes W123 Glove Box Liner: step 7, image 1 of 1
    • Now the glove box liner will pull out by hand.
Nicolas Siemsen
39,140 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,498 Guides authored
Past 24 Hours: 9
Past 7 Days: 17
Past 30 Days: 82
All Time: 11,191
