Prerequisite Lower Half Casing Disassembly
  1. Prerequisite Lower Half Casing Disassembly, Exterior Housing: step 1, image 1 of 3 Prerequisite Lower Half Casing Disassembly, Exterior Housing: step 1, image 2 of 3 Prerequisite Lower Half Casing Disassembly, Exterior Housing: step 1, image 3 of 3
    Tool used on this step:
    iOpener
    $24.99
    Buy
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
  2. Prerequisite Lower Half Casing Disassembly, Lower Half Casing: step 2, image 1 of 3 Prerequisite Lower Half Casing Disassembly, Lower Half Casing: step 2, image 2 of 3 Prerequisite Lower Half Casing Disassembly, Lower Half Casing: step 2, image 3 of 3
    • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
    • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
    • Lift and remove the counterweight.
  3. Prerequisite Lower Half Casing Disassembly: step 3, image 1 of 3 Prerequisite Lower Half Casing Disassembly: step 3, image 2 of 3 Prerequisite Lower Half Casing Disassembly: step 3, image 3 of 3
    • Lift and remove the plastic casing.
    • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
    • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
Jerrell
730 Reputation
7 Guides authored
Cal Poly, Team 11-50, Amido Spring 2014 Member of Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 377
