Up to 20% off select tools
Disassembling Logitech K250 Keyboard
View statistics:
Past 24 Hours:
0
Past 7 Days:
14
Past 30 Days:
41
All Time:
41
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to open the Logitech K250 Bluetooth keyboard (model YR0107). Opening it lets you clean the membrane layers and rubber dome sheet after a liquid spill, or access the circuit board for repair or inspection.
    1. Disassembling Logitech K250 Keyboard, Flip the keyboard around: step 1, image 1 of 3 Disassembling Logitech K250 Keyboard, Flip the keyboard around: step 1, image 2 of 3 Disassembling Logitech K250 Keyboard, Flip the keyboard around: step 1, image 3 of 3
      Ask FixBot
      • Stick your nail or something thin in the opening and open the compartment
      Ask FixBot
    2. Disassembling Logitech K250 Keyboard, Remove the top 2 grip pads: step 3, image 1 of 1
      • Grab your flathead screwdriver and carefully pry them off
      Ask FixBot
    3. Disassembling Logitech K250 Keyboard, Unscrew: step 4, image 1 of 2 Disassembling Logitech K250 Keyboard, Unscrew: step 4, image 2 of 2
      • Unscrew the 6 visible screws
      • Unscrew the 2 hidden screws (behind the pads we just removed)
      Ask FixBot
    4. Disassembling Logitech K250 Keyboard, Pry open the casing: step 5, image 1 of 1
      • Use a card/spudger and slip it into whichever corner seems easiest to get into
      • Gently pry open the casing by slowly moving around the sides
      • If you need to, you can use another card/spudger in the already unclipped spots to prevent yourself from accidentally closing it again
      Ask FixBot
    5. Disassembling Logitech K250 Keyboard, Finished: step 6, image 1 of 3 Disassembling Logitech K250 Keyboard, Finished: step 6, image 2 of 3 Disassembling Logitech K250 Keyboard, Finished: step 6, image 3 of 3
      • Clean/replace whatever seems to be the issue with your device
      • <3
      Ask FixBot
Jean-Pierre Coetzee
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 41
All Time: 41
